Author Topic: Advice on installing vertical stacking 2/70 and 23cm antennas  (Read 61 times)
EI3ECB
I have just purchased the Icon 9700 and for the first time I have to install the appropriate antennas for the 2metre , 70cm and 23cm bands. I have  ordered a Diamond X7000  vertical tribander , a dual  2/70 band  with separate  feeds and a 23cm . The 2/70 and 23cm are for side band use. I would appreciate any advice on the following couple of question:
I have been advised to use a non metallic pole especially for the 23cm antenna and I have access to some GRP 50mm scaffolding poles which I think is glass fibre reinforced plastic used as scaffolding poles. Would it be safe to use a 4 metre length of this to mount the three antenna?
Obviously the vertical tribander will be at the top of the pole but in what order should the other  2 antenna be and what would be a safe separation for the three antenna?
Sorry for my ignorance but I’m anxious to gain as much information for safe and reliable installation before I commence work.
Thanks
David EI3ECB/ G7KNW
