I'm picking off the states I need for 5BWAS.
VOACAP showed greater than a 90% chance of propagation (100 watts cw 1/4 wave vertical ) between Minnesota and Hawaii for several hours on both 40 and 80 meters during the Hawaii QSO party last weekend.
I worked several Hawaii stations on 40 but none on 80.
I called CQ HI on 80 cw around 0700Z, but didn't make any contacts or see any reports from Hawaii on reverse beacon net. I had a S5 noise level and was hoping a contester in Hawaii with a Beverage antenna could hear me. My 80 meter antenna is a vertical consisting of a 40 meter inverted vee up 30 feet fed with window line shorted together and run against ground with a tuner.
I did see spots from W6 and W2 call areas hearing Hawaii on 80.
Will I have a better change of working Hawaii on 80 this winter when the noise floor is lower due to reduced number of thunderstorms?
Should I have tried at 1000Z instead to get a boost from gray line?
Lynn WB0U
