Author Topic: receiving question  (Read 478 times)
KB0TXC
receiving question
« on: November 08, 2020, 08:54:15 AM »
Hi All,
I have a question for the collective wisdom of the forum readers... I soon will have two general coverage receivers, an  Icom R-71 that I have had for years and just had converted to 12 Volt operation as well as being recapped, and a soon to be acquired Low HF-150. I have a random length long wire antenna with a 9:1 balun that works reasonably well. It is possible to use one antenna for two different receivers at the same time? I am sure that I will need a matching network, but do not know where to start researching this idea. Thank you all in advance!
7s
Joe KB0TXC
NNNN
W6MK
Re: receiving question
« Reply #1 on: November 08, 2020, 10:25:07 AM »
Bonito makes an active RX signal splitter. Cost is about $300.
MFJ makes a passive splitter for about $20.
A switch will be simpler and cheaper.
« Last Edit: November 08, 2020, 10:29:40 AM by W6MK »
K6AER
« Reply #2 on: November 08, 2020, 10:47:50 AM »
A CATV spliter  ($3.00) will work fine.
VA3VF
« Reply #3 on: November 08, 2020, 12:29:39 PM »
I had some money burning holes in my pocket and got this one:
http://www.crosscountrywireless.net/multicoupler.htm
KL7CW
« Reply #4 on: November 08, 2020, 08:54:50 PM »
I was surprised my inexpensive CATV splitter from one of the box stores had significant port to port isolation in the VHF range.  I never did an exact measurement, and have no idea how much the port to port isolation is down at the I believe 5 MHz lower limit, but I would just try one.  The loss at VHF was close to the 3 dB you would expect, and some loss at SW frequencies is not usually a problem at all. Later, if really necessary, you can always upgrade to an active splitter or amp.  The splitters I have are 75 ohm, which will probably work fine with typical receivers.  You can get some screw on type F connectors at a box store. Most likely it will work fine below 5 MHz even with a bit more loss down there.   Rick  KL7CW
N8YX
« Reply #5 on: November 10, 2020, 08:17:22 AM »
Mini Circuits makes a 2-port, 50-ohm splitter (ZSC-2-4) that's good from 0.5 to roughly 30MHz and has very good port isolation. I have a couple which I use when running my IC-720A/R-70 or IC-751A/R-71 combos. They can be found on eBay for around $10, give or take.
W6UV
« Reply #6 on: November 13, 2020, 02:30:14 PM »
A passive splitter is going to result in a 3dB signal loss to each receiver. On HF, that's not usually much of an issue, so give it a try. If the 3dB loss makes a difference, you can turn on the rig's preamp (if it has one), or spring for an active splitter, which will be much more expensive.
« Reply #7 on: November 22, 2020, 03:33:46 PM »
Closer to 4dB when all losses considered. The CATV ones have more loss at low HF and less port to port isolation, coupling is mostly strays at those frequencies; take one apart and look!  I built my own in one of those boxes.
