I would shut off circuit breakers, one at a time. Then look at everything connected to the offending circuit (assuming the problem goes away with one of the breakers off). Depending where you live, it may also be coming from a neighbor's home. Also, if the problem exists on 160m, you could try to sniff it out with an AM radio, as someone else had suggested.
