Author Topic: Programming Band Edges on IC-7300  (Read 154 times)
K1KIM
« on: January 19, 2021, 05:37:33 PM »
I have programmed all the band edges for the allowable frequencies designated to my General license except for 10M.
It seems that the waterfall will not show more than 1 MHz 28.300 to 29.300.
I can set my beeps and make it so I cannot transmit outside of my bandwidth, but the edges set for the waterfall will only take a setting of 1 MHz. This is in No. 1,2,3 positions.
Can the Grid be changed from 10 MHz to a smaller number?
Any help is welcome as I wold like to see the full scope for my bandwidth.
The way it is right now I can't see any signals outside of that 1 MHz width.
« Last Edit: January 19, 2021, 05:41:56 PM by KE8BFN »
K1KIM
Re: Programming Band Edges on IC-7300
« Reply #1 on: January 19, 2021, 06:15:53 PM »
I think I might have to split the band width into two different edge groups.
No. 1     28.300-29.000
No. 2     29.000-29.700
Correct me if there is another way.
