Author Topic: M2 2M-440XPSS dualband yagi opinions  (Read 112 times)
« on: January 22, 2021, 09:20:45 AM »
Is anyone using the M2 2m-440XP dualband yagi on the satellites?  I have been thinking of getting one to improve my current base setup, and would be mounting the 2m elements horizontally which would put the 70cm elements vertically.  Does the yagi give a pretty good take off angle for most of the satellite pass if you don't use elevation?  Does it work pretty good overall as a satellite antenna?
