Author Topic: need help setting up paths  (Read 195 times)
KC1KQY
« on: February 04, 2021, 04:59:27 AM »
I'm trying to get setup with APRS but cannot seem to get it working. I'm using aprsdroid with a smart phone, a wolphilink and a Yaesu FT-818. In aprs droid my setting are, smart beaconing, GPS is on, Frequency is set to 144.39 FM, my path is set to WIDE1-1, WIDE2-2. I can here packets coming in, My radio transmits and seems to be sending packets. When I look at APRSdirect, I don't show up on the map, I can see a repeater 10 miles away. I can also see that same repeater on aprsdroid sending packets. I'm using a Mobil mag mount antenna on the truck and can hit many repeaters in the area so I'm  thinking that I should be able to reach out and hit an aprs repeater. Any ideas on what I should try next? Also, can anyone explain what all the information is in the station history? Thanks for the help!!
Steven
NA4IT
Re: need help setting up paths
« Reply #1 on: February 04, 2021, 05:18:10 AM »
OK, here's an idea. APRS is a "one shot" data transmission. It's not like some other data modes that keep sending until the receive station gets the data.
I used run APRS a lot, and also managed several APRS digipeaters. A rule of thumb to get "on the map"... good antenna, good power.
You... mag mount antenna... low power.
If you could put a metal mounted 5/8 wave antenna on your vehicle, you might be able to use the 818.
VK2ICJ
« Reply #2 on: February 04, 2021, 10:25:45 PM »
It's simple but check to ensure you are transmitting simplex.  My old FT897 now tasked as my APRS machine if I tune to the local APRS frequency in VFO mode it will automatically default in a negative shift.
Steven
cq cq cq de vk2icj
