My MMTTY macros are setup from F1 - F9. To activate them I simply press their corresponding F key. Something recently happened where pressing their F key alone will not trigger the macros. There is a drop down box in MMTTY where you setup how you want to trigger each macro. If I select Shift+F1 the macro will trigger just fine. If I select ALT+F1 it will work as well. In fact, any of the drop down box's selections will trigger F keys as long as I amend the F key with something else. (F1+ALT, etc)
Question:
How do I revert back to a simple press of the F keys button triggering a macro?
Tom KH0/KC0W
