Author Topic: Dog fence works on 10.65kHz. Will ham bands interfere?  (Read 265 times)
AE5KG
« on: March 08, 2021, 11:41:16 AM »
I don't want to shock my dogs accidentally when I transmit.  Well, it might actually be funny, but my wife won't like it.
ETA, also wondering if this will be picked up on IC-7300 as interference.  Not on the air yet.  Soon.  Need to get tower up this weekend.
K7AAT
Re: Dog fence works on 10.65kHz. Will ham bands interfere?
« Reply #1 on: March 08, 2021, 12:31:06 PM »
10 KiloHertz is an awful low frequency.  I cannot imagine any mutual connection to your ham radio equipment . .. .
KF5LJW
« Reply #2 on: March 08, 2021, 12:36:33 PM »
Should' effect a thing. Your antenna is far more dangerous than the fence charger. The fence charger by design cannot deliver a lethal shock. Ever seen a ham put up a protective barrier around a ground mounted vertical as codes require? Nah!
W6MK
« Reply #3 on: March 08, 2021, 01:48:29 PM »
Just don't wear the collar when you're on the air.
« Reply #4 on: March 08, 2021, 01:57:46 PM »
If you start barking you'll know there is a problem.
KA1CNK
« Reply #5 on: March 08, 2021, 02:11:58 PM »
I think this is a shock collar on the dog, not an electrified fence.  Guessing there's a 10 khz signal radiating from the perimeter wire that's acting as the electric fence.
« Last Edit: March 08, 2021, 02:14:20 PM by KA1CNK »
KF5LJW
« Reply #6 on: March 08, 2021, 02:44:35 PM »
My bad. Still should not be a problem. Test it first. Put it on your leg and key up. Better yet around wifey's leg since she is concerned. .
WA9AFM
« Reply #7 on: March 08, 2021, 02:48:24 PM »
I did that once because we had a bunch of youngsters in the neighborhood.  I added a sign announcing "DANGER!! 50,000 ohms".
WX7Q
« Reply #8 on: March 08, 2021, 04:54:05 PM »
Just use a "Woofing" filter. You should be OK.
« Reply #9 on: March 08, 2021, 06:31:41 PM »
Wow, that is a dangerous amount of ohm's. :)
KA1CNK
« Reply #10 on: March 11, 2021, 12:05:25 PM »
[/quote]
[/quote]
Anyone even notice the joke?
VE3TMT
« Reply #11 on: March 12, 2021, 07:03:17 AM »
 :P
