As many of us, I built a high voltage (160V or so, 300ma) bench power supply. One hazard is when it is lightly or no loaded, its filter caps will keep a high voltage charge for a good long time. I figured a good way to reduce this hazard is to have a bleeder resistor cut in when turning the supply off. I just needed a double pole double throw toggle switch (to replace the single throw single pole I used before). One pole does the powerline, and the other pole will connect the bleeder resistor to the high voltage output when the switch is thrown to "power off". I used a power resistor of about 2500 ohms 10W as the bleeder. This discharges the caps in about 10 seconds. Yes, the caps are fairly big. 120VAC secondary to a cap, then a choke, and another cap.
Having the bleeder not connected while power is on cuts current waste, until I need it when I turn it off.
+-------------------- transformer primary
powerline---o o o nc
ON OFF switch terminals
nc o o o----resistor------B+ supply output
ground nc= no connection
