Author Topic: Welcome to Cycle 25 by Steve Ford WB8IMY (Free pdf by the ARRL)  (Read 371 times)
W4KYR
 Steve Ford WB8IMY explains Cycle 25 in this freebie pdf by the ARRL
"A new solar cycle is under way and conditions on the HF bands are already improving."
http://www.arrl.org/files/file/QST/This%20Month%20in%20QST/2021/04%20April%202021/0421%20FORD%20CYCLE%2025.pdf
Re: Welcome to Cycle 25 by Steve Ford WB8IMY (Free pdf by the ARRL)
« Reply #1 on: April 19, 2021, 11:53:04 AM »
I missed solar cycle 23, I was on 2m simplex radio and monitoring analog fm pd vhf, but I wish I would have gotten active on HF.
From  the article above, the graph showing cycle 23 was good one, darn.
While I am here posting, was 23 a good one? and do most hams think conditions are changing for the better?
« Last Edit: April 19, 2021, 11:55:36 AM by KC6RWI »
AC7CW
« Reply #2 on: April 19, 2021, 12:56:56 PM »
Some tutorial level info about solar cycles: https://en.wikipedia.org/wiki/Solar_cycle
Cycle 23 was ok but 22 was better. In cycle 22 I used to work the world very nicely on 10 Meter FM with 10 Watts into a center fed vertical on top of my house. I was active in cycle 19 with a pile of junk for equipment and worked the world on CW.
« Reply #3 on: April 19, 2021, 01:39:05 PM »
FM? and I am sure you had ssb as well. I've never been set up to do FM during  peak conditions. Now my radios have that mode.
W4KYR
« Reply #4 on: April 19, 2021, 02:31:45 PM »
Speaking of 10 meter FM repeaters, does anyone remember the Virgin Islands 10 meter FM repeater with the doorbell sound ?
« Reply #5 on: April 19, 2021, 02:44:49 PM »
Wasn't that the Avon repeater?
AC7CW
« Reply #6 on: April 19, 2021, 07:12:18 PM »
I just like FM for the audio quality. It's legal above 29.500. To my way of thinking that is the best for mobile when the sunspots are high: You don't have to do any tuning because it's channelized so less distracted driving and a full size quarter wave antenna works on a car. Watt for watt the ability to make contacts is the same as SSB but it just takes more bandwidth. Possibly considering the not-so-compromised antenna it gets out better than SSB on 20Meters with the necessarily compromised antennas required for mobile. There are 10Meter FM repeaters as well, I've yet to use one. I'm looking forward to some good sunspots
