I am about to embark on getting rid of S9 to 20, over. (Noise)!
I am using a DX Commander Classic, 7 Band, 40- 10...(Works great by the way) /Rig is FT 450 Yaesu, /Amp SPE 1K
I assume, since the antenna I am using is vertical the best is to use a vertical antenna to feed the Timewave ANC - 4. I will use a wire length that is not a multiple of 10/12/15/17/20/30/40..
I will use 16Mhz, or a 1/4 wave length of 15FT (Aprx), (Which means 15FT vertical)
Any further advice using the Timewave ANC - 4..?
FYI: I have performed the following
1. Installed Baluns, chokes, ferrites beads...It did make a slight impact actually,
2. Turn the power from the house, and powered the transceiver with battery..Noise still there..
The noise I suspect is coming from the power lines, or my neighbors solar panels
My rig is FT 450 which has noise reduction, and host of other features to dampen the blow of the noise...All this is not able to knock down the S9 to 20 over S 9 noise that I have
I look forward to your responses..(And if any of you reading this post desires to sell a Timewave ANC - 4, please advise!)
NN2X / Tom
