That assumes that the wire size is rated for the
required current at the higher duty cycle of a
ham radio compared to a seat adjuster.
The seat motor probably will still operate at
10V under load, while your radio may lock
into transmit mode when the supply voltage
drops (had that happen to me with two radios:
in one case, the radio locked up at 50W, but
not up at 25 W with the engine running,
to voltage drop in the wiring. But when my
wife turned off the engine while transmitting
at 25W, it locked up, she locked the car, and
went off to her appointment. Took me about
half an hour to get there, find the car, unlock
it, and shut off the radio...
So even if the fuse is big enough, you may
find that the voltage drop through the
wiring harness is more than the radio can
handle at full power. You won’t know until
you try it.
