Author Topic: KWD TH-D74a/Mirage BD-35 Advice?  (Read 141 times)
N4SRN
« on: May 14, 2021, 04:47:37 PM »
I have a Kenwood TH-D74a HT and Mirage BD-35 Amp incoming. I would like to pull my Yaesu FTM-400XDR from my car and try the HT/Amp combination. Any advice on setup and use for dual use on APRS and 146.520 would be appreciated. Might just be temporary.
Bret/N4SRN
Bret/N4SRN
Bedford, NH  USA
N1IG
Re: KWD TH-D74a/Mirage BD-35 Advice?
« Reply #1 on: May 15, 2021, 03:38:34 AM »
did you read the reviews?  https://www.eham.net/reviews/view-product?id=3281
one of the posts mentions an issue with passing 222.
N4SRN
« Reply #2 on: May 15, 2021, 05:16:32 PM »
Seems like they work, or don’t. While a lot of don’t work reviews pop up, I’m hoping the adage about negative reviews being 10-fold more likely. Fingers crossed.
Bret/N4SRN
Bedford, NH  USA
LYFAN
« Reply #3 on: July 03, 2021, 01:47:16 PM »
Have used both the vhf and dual band mirage, as well as another discontinued vhf make. No problems at all, just plug-n-play. If you are buying new, just test it and return it if NG.
 The UHF side will be slightly less power than the vhf, and you'll want to run your h/t on full voltage to get the best power into the booster.
