Author Topic: Jeep Gladiator  (Read 500 times)
K4EMF
Jeep Gladiator
« on: May 16, 2021, 07:36:14 AM »
Anyone have any experiences mounting a mobile in a Jeep Gladiator?
Not just where you mounted the radio in the cab but where and how you routed the coax to the antenna.
I thought I'd try to take advantage of any lessons learned already before I start making holes to accommodate an installation.
KC9BUH
Re: Jeep Gladiator
« Reply #1 on: May 16, 2021, 07:05:27 PM »
I know this may not be much help,but look at 4dorr wrangler installs.
they would close to the same.
Good luck on your install
K4EMF
Re: Jeep Gladiator
« Reply #2 on: May 17, 2021, 06:30:34 AM »
"Not much help" ?  On the contrary my good man.  I have NO idea why I didn't think of that.  The models are practically twins.
Anyone know of where the coax was routed in a 4 door Wrangler?
W4DSL
Re: Jeep Gladiator
« Reply #3 on: June 02, 2021, 06:44:17 AM »
I mounted my Comet VHF/UHF antenna using a COMET-NCG CK-3NMO on the front left fender. Works good there.
K4EMF
Re: Jeep Gladiator
« Reply #4 on: June 02, 2021, 07:33:08 AM »
How / where did you route the coax?
W4DSL
Re: Jeep Gladiator
« Reply #5 on: June 02, 2021, 07:46:28 AM »
The door hinge and left cowling .Where the two meet. You need to use that antenna cable because its small diameter for the first 12” let’s it fit in the space. I would send you a picture if I knew how.
K4EMF
Re: Jeep Gladiator
« Reply #6 on: June 02, 2021, 03:31:50 PM »
The door doesn't crush the coax then?
W4DSL
Re: Jeep Gladiator
« Reply #7 on: June 02, 2021, 05:42:37 PM »
No. Look at the Comet part number I gave you. It’s made to go into door and trunk areas.
K4EMF
Re: Jeep Gladiator
« Reply #8 on: June 03, 2021, 04:34:48 AM »
I'll look it up, thanks.
K3GTX
Re: Jeep Gladiator
« Reply #9 on: June 04, 2021, 11:43:12 AM »
I have a 2019 JL with automatic transmission.  If you have an auto transmission there should be an extra plastic plug in the firewall (where the clutch would go through) that you can use.
K4EMF
Re: Jeep Gladiator
« Reply #10 on: June 05, 2021, 01:21:36 PM »
I had not noticed it but I will certainly be looking for it now, thanks.
