Hi,
I am planning to install a 41ft end fed antenna along the ceiling of my entertainment room. The dimensions are approx. 35ft by 15ft.
Question. So, basically, the end fed wire would be bent 90 degrees laterally along the ceiling. Would this work? I’ve read somewhere that as long as the wire is not bent back toward itself, it should still work...
Thank you.
Cho
N0AKX
