Author Topic: ISS Sending Slow-Scan TV Images  (Read 249 times)
« on: June 08, 2021, 12:17:36 PM »
SB SPACE @ ARL $ARLS005
ARLS005 RS0ISS Will Transmit Slow-Scan TV Images from the ISS on
June 9-10
ZCZC AS05
QST de W1AW
Space Bulletin 005  ARLS005
From ARRL Headquarters
Newington, CT  June 8, 2021
To all radio amateurs
SB SPACE ARL ARLS005
June 9-10
Russian cosmonauts on the International Space Station (ISS) plan to
transmit slow-scan TV (SSTV) images on 145.800 MHz FM June 9 and 10.
The transmissions, which will use SSTV mode PD120, are part of the
Moscow Aviation Institute SSTV experiment (MAI-75) and will be made
from RS0ISS in the Russian Service Module of the ISS using a Kenwood
TM-D710 transceiver.
The tentative schedule calls for transmissions on June 9 from 0935
UTC until 1350 UTC and on June 10 from 0855 UTC until 1550 UTC.
Dates and times are subject to change. Hams on Earth should be able
to receive the signals on a handheld transceiver using a
quarter-wave whip antenna, with FM filters set for 25 kHz channel
spacing.
N1IG
Re: ISS Sending Slow-Scan TV Images
« Reply #1 on: June 10, 2021, 09:00:11 AM »
I was able to pick up a portion of 2 passes this morning.  Using a handheld & whip antenna didn't let me get a good signal, so the pic was pretty fuzzy.
