Author Topic: Question on Using a Junker Straight Key  (Read 298 times)
KM6ZX
« on: June 11, 2021, 09:17:38 PM »
I recently acquired a very nice Junker straight key, in almost mint condition. It was manufactured in 1987, so is one of the later ones.
I wired up the key with my modern solid state transceiver and noticed a serious lag between key down and the transmitter actually keying. On further inspection, I noticed an LCR circuit under the key, so when the key makes contact, the switch actually closes a LCR circuit, and not a straight connection. It appears to be some kind of electrical filter or damper. Anyways, I carefully removed the resistor and capacitor part of the circuit and it now works perfectly. I left the inductor in place. Does anyone know the purpose of this circuitry? Is it for older high-voltage rigs? It seems to cause problems with my modern transceiver.
I made sure anything I do to the key is easily reversible, as I don't want to ruin a historical key.
73 - Brian KM6ZX
ZL1BBW
Re: Question on Using a Junker Straight Key
« Reply #1 on: June 11, 2021, 11:48:54 PM »
Ah, back in the old days, we used to shape our keying with a filter on the key, it also helped get rid of the clicks.
The really wide awake ops were inevitably using cathode keying, where if you fingers trayed there was often a 100 or so volts ac  ross the key contacts, that certainly improved your focus.
Cheers.
ex MN Radio Officer, Portishead Radio GKA, BT Radio Amateur Morse Tester.  Licensed as G3YCP ZL1DAB, now taken over my father (sk) call as ZL1BBW.
W6MK
« Reply #2 on: June 12, 2021, 04:04:19 PM »
The LCR network I removed from my Junker IS history.
The Junker is unlikely to be used for cathode or grid block keying in the future.
AC2EU
    • McVey Electronics
« Reply #3 on: June 13, 2021, 07:53:58 AM »
It was manufactured in 1987, so is one of the later ones. I made sure anything I do to the key is easily reversible, as I don't want to ruin a historical key.
I doubt that a key manufactured in 1987 has any historical value...or did you mean 1887?
