Quote from: K7JQ on December 26, 2021, 06:44:23 AMQuote from: K1FBI on December 26, 2021, 05:41:20 AMHas anyone tried running a CLRdsp into another CLRdsp and “double processing” it? I wonder if the two different algorithms on lighter settings would work better?I have two CLRdsp units for my two 7300’s and can try what you suggest. But the units have the same algorithms. As I stated in my previous post, I cascaded the CLRdsp with the NR in the 7300 (different algorithms), both at lighter settings with decent results. It seems to reduce the time frame “whoosh” of the noise abatement adaptation when changing from transmit to receive.Bob K7JQGreat, let me know how it works. I realize the algorithms are the same. I was thinking that once speaker 1 processed it, speaker 2 would choose an algorithm with a different attack pattern.I could be wrong in my assumption of how the units work.
Quote from: K1FBI on December 26, 2021, 07:52:50 AMQuote from: K7JQ on December 26, 2021, 06:44:23 AMQuote from: K1FBI on December 26, 2021, 05:41:20 AMHas anyone tried running a CLRdsp into another CLRdsp and “double processing” it? I wonder if the two different algorithms on lighter settings would work better?I have two CLRdsp units for my two 7300’s and can try what you suggest. But the units have the same algorithms. As I stated in my previous post, I cascaded the CLRdsp with the NR in the 7300 (different algorithms), both at lighter settings with decent results. It seems to reduce the time frame “whoosh” of the noise abatement adaptation when changing from transmit to receive.Bob K7JQGreat, let me know how it works. I realize the algorithms are the same. I was thinking that once speaker 1 processed it, speaker 2 would choose an algorithm with a different attack pattern.I could be wrong in my assumption of how the units work.I'm not sure what you mean with the speaker 1/speaker 2 scenario, as a unit can only feed one speaker or headphones. They each have a 10W audio amplifier, so I'm not gonna cascade one output into another's input. Maybe you're referring to the models with the built-in speaker? I have the stand alone models, needing external speakers.
