Author Topic: Jennings Vac Var operation  (Read 176 times)
ZL1BBW
« on: July 10, 2021, 01:41:52 PM »
What do I need to turn or pull in and out to make the capacity vary?
When I got this it did not have the nose cone thingy with a shaft to turn, so its sort of useless to me at the moment, but could really do with making it work.
[img]https://hosting.photobucket.com/images/r697/zl1bbw/P1000126.JPG?width=285&height=175&crop=fill[/img
It looks like a threaded shaft should go into the centre hole, is that what pulls it in and out?
Thanks
« Last Edit: July 10, 2021, 01:58:07 PM by ZL1BBW »
ex MN Radio Officer, Portishead Radio GKA, BT Radio Amateur Morse Tester.  Licensed as G3YCP ZL1DAB, now taken over my father (sk) call as ZL1BBW.
ZL1BBW
Re: Jennings Vac Var operation
« Reply #1 on: July 10, 2021, 08:45:14 PM »
Problem all sorted with a bit of ingenuity
