Author Topic: Cycle 25 forecast  (Read 469 times)
W7CXC
Cycle 25 forecast
« on: July 22, 2021, 09:02:15 AM »
Folks:
I seem to remember a forecast that was very optimistic based on the spots on the northern  and southern hemispheres going on at the same time rather than out of phase as in the last few cycles. The theory as i recall was that the in phase spots would lead to a single higher peak rather than dual , although lower, peaks. Very preliminary observation would lead one to think there may be something to this single high peak  forecast. Is there any updated info on this?
David
K4FMH
Re: Cycle 25 forecast
« Reply #1 on: July 22, 2021, 11:28:12 AM »
GRUMPY2021
« Reply #2 on: July 22, 2021, 12:55:46 PM »
Given our inability to predict hurricanes, viruses or tomorrow's weather I wouldn't worry about it.   It's 11 years long so just enjoy the hobby.  Even at the bottom of cycle 24 I was never disappointed.
N5PG
« Reply #3 on: August 04, 2021, 06:16:54 PM »
W7XTV
« Reply #4 on: August 04, 2021, 09:06:43 PM »
Agreed.  At the bottom of the sunspot cycle, use the lower MF/HF bands.  As the sunspot numbers increase, switch to 20-6 meters.  Also, use a mode that is conducive to working DX if that's what you want.  At sunspot minimums, that means CW or digital modes.
He speaks fluent PSK31, in FT8...  One QSO with him earns you 5BDXCC...  His Wouff Hong has two Wouffs... Hiram Percy Maxim called HIM "The Old Man..."  He is... The Most Interesting Ham In The World!
« Reply #5 on: August 05, 2021, 06:51:22 AM »
Another option, if you prefer working DX on SSB, is to improve your station.
I remember N6BUS, the XYL of KH6JNP, who was outfitted with a monoband 15M Yagi on a tower so they could communicate daily from Orange County CA to Honolulu Hawaii.  He would drive out to Sand Island and park right next to the water.  They hired him to maintain the radio gear at Honolulu International Airport.
A full size dipole a half wavelength or more above ground can be a significant improvement over compromise all band antenna.  Phone pileups can be very frustrating, as every loud DX station will attract a big pileup.  An amplifier may reduce the difficulty of getting through pileups.
Another approach is to work on eliminating local sources of noise, so you can hear weak DX stations.  There are a lot of 100W DX stations that would love to work stateside.  They can be worked if you can hear them.
Zak W1VT
« Reply #6 on: August 05, 2021, 08:09:42 AM »
Zak W1VT
Good post
