Author Topic: trying to set up remotehams  (Read 200 times)
EI9GMB
« on: August 14, 2021, 05:38:48 AM »
 anyone help i have set up remoteham.com  and forward port numbers and done check and the ports have passed.   but every time i open RCForb server and try to connect my server i keep getting this error   '' only one usage of each socket address (protocol/network address/port) is normally permitted     failure to start app open...    this is on remote hams server were you want to use it for remote   anyone else reconise the error   i tried sending screen shoot of issue but dont think ehams allow it.....   any help please
AC7CW
Re: trying to set up remotehams
« Reply #1 on: August 14, 2021, 05:45:28 AM »
I did that setup once and had no problems like you describe. There is a forum on their website, you might search that to see if others have encountered it, if not you can start a thread.
EI9GMB
« Reply #2 on: August 14, 2021, 06:26:25 AM »
thank you will do that
AC7CW
« Reply #3 on: August 14, 2021, 03:19:28 PM »
