I have tried connecting my Alinco DR=735T and a WestMountain Rigblaster DxPro using Windows 10 to operate WinLink. I have not had any luck. The radio manual indicates the mini DIN socket on the rear should be used to connect to any external TNC. The Rigblaster only comes with a connection to the mic jack on the radio which West Mountain tells me should work. Has anyone else tried this and if so how did you make it work. Also if the mini DIN socket on the rear of the radio is the only way, then any recommendations on a TNC that will work?
