G5RV…no where near the cable line
Common mode choke/balun at junction of parallel line and coax?
Yes….and I made a discovery….this new found interference with the tv does not happen while running barefoot….only with my 400w AL-84 amp transmitting…..game changer?…
V
K3NRX
Obviously, Vince, the issue ultimately is the amp. You need to get rid of it.
Not to worry, I’ll make sure it gets a good home. You can bring it with you to the Butler hamfest on Sunday... or to Flynn’s Tires in Kirwan Heights...
