Hi Peter,
You may want to try the same antenna but fed in the center of one of the vertical sides. This will give vertical polarization and may not "short out" to the ground as much as the version fed at the center of the bottom horizontal section. I've been wanting to try this myself but haven't yet. I have modeled it with descent results but the "proof is in the pudding".
Steve - AA5TB
