@ZL1BBW
Thank you for that call sign. I found his webpage and it's stacked with HF Pedestrian and Bicycle Mobile HAM.
I'll share the link
https://www.g4akc.co.uk@everyone
I continue to experiment. I found a nice, waterproof, handle-bar mounted pack to put my radio and tuner in. They fit nicely. Still trying to sort out an antenna to use while being in motion that will rear mount to my bike rack without dragging any wires behind me. I mentioned the WonderLoop antenna as possible candidate, so I'm trying to get my hands on one of those to try. The WonderLoop mounts to the rear of the radio, but I'm sure I would be able to mount it a rear of the bicycle, with a patch cable going along the bike's crossbar to the handle-bar mounted radio. IA patch cable a few feet in length might do the trick. Very excited to to try this out.
Everything is coming together nicely and hopefully before Winter I can make my first contact while pedaling.
On a side note, I came across a YouTube video of K8MRD working Parks On The Air. What I found interesting was on the radio he used, the FT-891 , there was a built-in Record Playback Option that was used for recording his voice saying, "cq cq, callsign, park ect." and that was transmitted at the push of a button. What a coinvent feature to have while mobile. This feature would be pretty handy to have on a bicycle mobile trying to make contacts. I do not believe the FT-818 that I have has this function. Something to sort out later I'm sure.
Oh, I almost forgot. Working CW has been mentioned a few times, being QRP, Mobile, and with such a small antenna, this could work out quite well. But probably not while cycling, working a key might be difficult, but not impossible. Then there is the fact that, I do know know Morse Code. I've tried and tried hard. But I just keep forgetting letters. I'm sure I can learn it, that's not impossible either.
If I remember correctly, one of the Elecraft radios translates Morse Code into Text on its LCD display. Is that correct? Maybe it even has preset functions to transmit Code. If so, that could be very handy indeed. I'm open to methods of learning CW.
This update has been all over the place, thanks to those who are following the tread and keeping up with the rag chewing.
Have a great rest of the weekend everyone.
