Author Topic: CW Filters for TT Eagle  (Read 194 times)
K2TPZ
« on: September 29, 2021, 07:14:41 AM »
I would like to add a CW filter to my Ten Tec Eagle. But Ten Tec and INRAD no longer stock them. Does anyone know where such filters can be purchased?
 Thanks, Mike, K2TPZ.
KA4DPO
Re: CW Filters for TT Eagle
« Reply #1 on: September 29, 2021, 07:18:45 AM »
Unfortunately those are really hard to find.  About all you can do is keep looking, one might pop up now and then.  Sorry, but that is going to be a very difficult find.
AE0Q
    • AE0Q Amateur Radio
« Reply #2 on: September 29, 2021, 08:44:22 AM »
Have you called TT to ask about the filter?  I got this from them in mid-June.
"We have the 600 Hz CW filter in stock for the Eagle . We do not have available the
300 Hz filters at this time. If you would like to order you can call 865-365-2295.
Thank You
Ten-Tec Service Department"
I have an Eagle with the 600Hz and it works well on any narrower settings of the DSP filter, I'm constantly changing it from around 200-550Hz when on the air.  I don't think a 300Hz roofing filter would be necessary anyway, although I don't have huge antennas.
« Last Edit: September 29, 2021, 08:57:57 AM by AE0Q »
NSGA Edzell 1974-77  CTM2  GM5BKC : NSGA Rota 1972-74   ZB2WZ, SV0WY
https://radioandtravels.blogspot.com/
http://www.qsl.net/ae0q/
W4MSL
« Reply #3 on: September 29, 2021, 05:54:57 PM »
How much trouble and expense are you willing to endure? There's a one-owner "mint TT Eagle w full complement of filters on eBay right now. 15 bids and $616 (!) so far. You could, I suppose, bid on it, and if you get it, pull the filter and try to resell the extra rig for a lower price after pulling the filter. Methinks you'd lose money that way, but maybe not so much as to make the idea totally absurd. It's a lot of bother for a filter. It might be more reasonable to look for a "parts only" Eagle if you can verify that it has the wanted filter. A saved search on eBay for the exact filter w part number might eventually turn up just the filter. I'd definitely try that route. And, certainly post a WANTED classified on eHam.net. Good luck from another TT owner!
K2TPZ
« Reply #4 on: September 30, 2021, 07:57:20 AM »
At this point I’m not willing to purchase a second Eagle to obtain CW Filters. Eventually one might show up. I’ve reached out to several crystal and ham outlets as well as on forums such as Eham. I can be very patient. Thanks for your input. Mike
