Author Topic: FTM-400 Keypad Problem  (Read 95 times)
WA9AFM
« on: September 29, 2021, 10:25:45 AM »
Have an FTM-400 in the car.  I was trying to manually reprogram the APRS 'tag' (APRS menu, #23), but discovered if I try to key in '1' or 'Q', the input jumps to '2' or 'W', the next number/letter to the right.  If I program with an SD card, everything works fine.  Has anyone encountered this problem and is there a fix?
