Are both keyers doing that stand-alone, i.e. not connected to your rig or any software?
If so, there is a WinKeyer parameter that will lengthen the first dit or dah called 1st Element Extension. That parameter lets you lengthen the first element in increments of 1ms up to 99 ms. It is intended for use with old xcvrs with slow VOX or other setups where the rig or switching shortens that first element.
Depends on how old your Winkeyer is on how that parameter is set, but look in whatever .pdf file manual for your keyers and look for 1st (or "First" as it different versions of the manual use 1st or First) Element Extension and see how it is set.
73 John K3TN
