Author Topic: Can I run a 4.5 volt LED headlamp on 5 volts?  (Read 428 times)
N1AUP
« on: October 09, 2021, 02:47:17 AM »
I have a headlamp that runs on (3), AAA batteries.  I use it when doing barn chores at night.
The AAA batteries don't last very long, so I was thinking of attaching a 4.5 volt, rechargable pack that is larger than the 1 amp hour AAA cells that it currently uses.
I thought that using a rechargable USB pack might be an easy way to do this, but USB is 5 volts.
Can my LED light handle 5 volts instead of 4.5, or is that going to eventually destroy the circuit?  If the latter, what is the simplest way to drop the voltage?  A resistor?  What wattage?  Use P=I*E?  I'm guessing I can use ohms law, while measuring the current draw of the light to figure out the required resistance as well.
Thanks
K1MMI
Re: Can I run a 4.5 volt LED headlamp on 5 volts?
« Reply #1 on: October 09, 2021, 03:34:32 AM »
A rectifier diode like a 1N4001 thru 1N4007 drops the voltage by .6 volts.
W1RKW
« Reply #2 on: October 09, 2021, 04:23:04 AM »
Use Eneloop rechargeable batteries.
N1AUP
« Reply #3 on: October 10, 2021, 02:28:55 AM »
You're right.  Forgot about that.  The perfect solution.
N1AUP
« Reply #4 on: October 10, 2021, 02:29:54 AM »
I'd like to use something with more capacity.  The AAAs start running down after a few hours, and light gets dim.
N7EKU
« Reply #5 on: October 10, 2021, 04:00:05 AM »
Hi,
I'm pretty sure that these lights already use an internal voltage converter to reduce the voltage to a precise lower value. It would be fine to run on a 5V pack as is. Anyway, the three cells probably make close to 5V when brand new.
Mark -- N7EKU/VE3
« Reply #6 on: October 10, 2021, 06:03:27 AM »
Always keep in mind that the simple (bare) LED is biased with current, not voltage. The resulting voltage drop is merely a byproduct of the current passing through the diode.
N7EKU
« Reply #7 on: October 10, 2021, 07:02:09 AM »
Right,
It's more likely current limiting used in these lights.  As such, a bit more supply voltage would still be OK as long as the regulator can dissipate the bit extra heat OK.
More coffee :-p
Mark -- N7EKU/VE3
