used /Am for years mostly phone so the other guy had a clue
what I was up to.
Did that both HF and VHF/UHF. Works well with suitable antenna.
THe ADF wire could be repurposed for HF (assuming VFR) and
depending on the plan copper tape on the windows in a safe
non-obstructing location is good for higher frequencies.
Like some said managing the audio and PTT is a must as you may
have to fly the plane and that is for the uninitiated first priority.
Easier if your a passenger or both pilots. The down side from
4000ft its not hard to key every repeater that can hear you (radius
is 150-200 miles++) or on .52 create a pile up.
Allison
