Author Topic: R390A  (Read 660 times)
Re: R390A
« Reply #15 on: October 20, 2021, 02:50:01 PM »
Now if you want a serious tube radio look at the National AN/FRR-59 and AN/WRR-2 and 2A.
W3SLK
Re: R390A
« Reply #16 on: October 22, 2021, 08:36:13 AM »
Joe, N3IBX(SK) had one of those. John, W3JN came up and got it working for him. I never had a chance to play with it but without a doubt it is the penultimate boat anchor reciever!
Re: R390A
« Reply #17 on: October 22, 2021, 08:58:11 AM »
There is very little that Johnny Novice couldnt fix!
W1BR
Re: R390A
« Reply #18 on: October 27, 2021, 08:36:56 AM »
I've never owned a R-390A, but I have grabbed a few IF decks to salvage the filters for other projects.  I've found they can have greater than expected pass band ripple or are very lossy... some of the materials used in the filters outgasses and contaminates the resonant discs.  Make sure the four filters are within spec before plunking down serious cash.
W9WQA
Re: R390A
« Reply #19 on: October 27, 2021, 09:10:24 AM »
worked on them at stewart warner in 63.
woulda died 4 one then.
dont send me a free one now...
AA4HA
Re: R390A
« Reply #20 on: November 16, 2021, 08:04:08 AM »
Having taken apart bad filters to fix them one of the issues is the foam rubber that they used as mechanical isolation on either end of the stack of dimes (my term for the little metal disks that are welded together with wires in strategic ways to determine the filter bandwidth). The foam breaks down after 50-60 years and turns in to a "goo"; The stuff gets everywhere inside of the filter and is a PITA to clean up (solvents and lots of cotton swabs).
It is a daunting task to take apart to restore the Collins tubular mechanical filters. The most common way a filter dies is to have the "killer cap" short out and it puts B+ through the input coil on each filter until it burns out a winding (also, not a fun thing to rewind this tiny little coil the size of a pencil eraser). Another way is from excessive mechanical movement (maybe amplified by the foam turning in to goo, or bad practices on disassembly). This tiny little steel needle that sticks out of each coil (facing to each other) can break off, and there is no way to fix that; you can't solder it, you might be able to spot weld it but it won't be the right length or temper or be in the exact perfect spot.
In my parts scavenging I ran across an IF deck with a complete set of Clevite ceramic filters (rarer than rare); that deck is for a special radio I am building (the penultimate radio). I have added a roofing filter between the RF and IF stages, made changes to component values and capacitor types in the AF deck (to reduce THD), Upgraded power supply caps, installed a solid-state, german-made ballast tube replacement  and hand picked tubes for every spot.
Even with all of that, it is probably one of the best, gold-plated versions of the R-390A that is out there; But still, it is an R-390A and lacks a decent SSB facility. I have Cubic's, Racal's and WJ's that perform better and even a SDRplay that is more fun to use.
Ms. Tisha Hayes, AA4HA
Lookout Mountain, Alabama
KA4KOE
Re: R390A
« Reply #21 on: November 16, 2021, 10:35:10 AM »
I have a restored R390 (1951), Serial 495. Its a fantastic receiver. IIRC, this version had 30+ tubes and used multiple LC filters for the various bandwidths.
Re: R390A
« Reply #22 on: November 16, 2021, 02:30:12 PM »
A great receiver but rather finicky to keep running, a PITA to align, and cost kept going up so the 390A was produced.
Mine is shared with a 51J4, HRO-60, SX-73 and R-274D, HQ-180 with factory Noise Slencer, and HRO-500/LF-10 on a rotational basis.
It is an all Collins 1955 run
I do all my overhaul/rebuilding work
K3UIM
Re: R390A
« Reply #23 on: November 16, 2021, 02:57:07 PM »
"It is an all Collins 1955 run"
Jeepers! And some of us have a mono-band DC receiver! :'( :-[ ::) ;D ;D
It all depends on what you want to sail your boat. LOL (You've certainly earned whatever you have, Carl!!)
Charlie
Charlie. K3UIM
Where you are: I was!
Where I am: You will be!
So be nice to us old fogies!!
Re: R390A
« Reply #24 on: November 16, 2021, 03:19:30 PM »
Charley, it took me a couple of years to get Collins modules that had serial # close to the mainframe. This was ~40 years ago before the collector market went crazy. Yes today it has gained a lot of value thanks to my perseverance ;D
K3UIM
Re: R390A
« Reply #25 on: November 16, 2021, 06:42:16 PM »
"You done good, man!"
\Charlie
Charlie. K3UIM
KA4KOE
Re: R390A
« Reply #26 on: November 18, 2021, 09:07:12 AM »
"A great receiver but rather finicky to keep running, a PITA to align, and cost kept going up so the 390A was produced."
Agreed. But, warts and all, I like it.
PAN
