it is wide cu strap to the 450 ohm globar. The normal deal with grid driven tetrodes is the tube C is XC..and esp on the upper HF bands..which ends up in parallel with the globar. Normal deal is to use a small coil in parallel with the globar, to cancel out the tubes XC. I see on the alpha amps that are grid driven, they relay switch in the coil, but only on the upper HF bands. The grid driven alpha amps use a 1:4 un-un and a 200 ohm non inductive resistor.
In this case, we have lousy swr... before the tube is even in the picture. The 450 ohm globar has to handle a fair whack of power for this application, so 1/8 watt resistor is a moot point.
I suspect the wrong type of core was used, so it would be better to optimize that....1st. He has some type 67 coming next week. He will try that, and also some type 61....and also type 43. The trifilar winding consist of teflon coated wire.
