RE: "FT8 has a wider bandwidth than the typical rig with a 2.4 kHz crystal filter, more like 3 kHz."
WHAT?
? If your FT8 signal is 3Khz wide, you are doing something BAD WRONG!!!! lol
I add a vote for the IC-7100 or IC-7300. Stay AWAY from the FT-891, it has one of
the "nastiest" TX that the ARRL has tested and they even say "don't hook to an amp or even a good antenna" !!
The FT-991A TX is almost as bad.
The IC-7300 has, by far, the best RX in that price range.
