The power supply negative is grounded thru the transceiver.
Quote from: N8FVJ on December 22, 2021, 03:47:29 PMThe power supply negative is grounded thru the transceiver.assuming the radio is grounded.if radio is connected to the supply with line volts on dc and you touch the radio as you connect the ground, you get shocked.ground the dc to chassis ground...
