Author Topic: Scrolling Problem Fixed - Try This  (Read 313 times)
N5INP
« on: November 19, 2021, 06:36:12 AM »
I'm starting this new thread because I think others may be tired of the other "scroll problem" thread, and not view this solution if posted there. This fixed the irritating scrolling issue (double scroll bars) for me while using the standard eHam forum profile - apparently permanently. I'm using the latest Firefox. I've asked another eHam member to try it also and he told me it worked for him too.
First, go to your account and change the forum theme style to "eHam mobile" (you will not be keeping this setting though). See picture below. It's saved automatically when you select it -
Go to the forum and check out how it looks to make sure you are in the mobile theme. This, as it is, removes the scrolling issue, but we're not done yet (unless you like the mobile theme, then you can stop here).
Next, again go back to your profile and change back to the standard eHam theme. I found on my system that the scrolling issue is still fixed. Some setting has been changed and it's now removed the double scroll bar scrolling issue for the standard eHam theme. I closed the forum, closed the browser, reopened them, and the scrolling problem is still fixed. I went to other areas of eHam that I never use, and the scrolling was still fixed when I went back to the forum. When I close eHam and re-open it, I can see that double scroll bars appear at the right for about 1/2 second, but it then changes to a single scroll bar.
It sure is nice to have that issue fixed for the standard forum theme. Try this and let me know if this works for you.
« Last Edit: November 19, 2021, 06:39:54 AM by N5INP »
Help out the Club Log QSL Card Tagging Project - Tag DX QSL Cards. All scanned cards have been tagged but more are coming soon.
Re: Scrolling Problem Fixed - Try This
« Reply #1 on: November 19, 2021, 07:40:21 AM »
N5INP,
 Amazing, you fixed it.
I did as you said and it worked perfect. I switched back to regular eham, went out of Mobile and it still works. Great work and thank you.
Jim. W5JJG
N5INP
« Reply #2 on: November 19, 2021, 07:55:43 AM »
N5INP,
Jim. W5JJG
Great!  :)
« Reply #3 on: November 19, 2021, 08:07:43 AM »
It seems to be a durable fix, surviving a reboot of the PC and all.
N2MG
  • Administrator
« Reply #4 on: November 19, 2021, 12:07:00 PM »
We just made some additional tweaks to the forum earlier this week, patching some holes in the scroll "fixes" that we had worked in some time ago (some OS/browser combos were still showing those scroll bars)
Looks like choosing a different theme (from the default) and then going back to the default loads the corrected default theme.
Good eyes!
Mike N2MG
webmaster
N6MST
« Reply #5 on: November 19, 2021, 12:24:42 PM »
Henceforth he shall be known as INP the Great, a prince among men!
K5EMG
« Reply #6 on: November 19, 2021, 12:30:57 PM »
Good eyes!
 You need to add www to the link, it's what I normally do to be able to read the post in Safari and iOS. Under windows, it's added always. I tested with Edge under MacOS and didn't work (without adding the www part), the same navigator under windows works perfectly, and has the www added automatically.
W7XTV
« Reply #7 on: November 19, 2021, 04:07:23 PM »
I think I like the Mobile format better than the Eham.  Works much better on my phone, and is much faster on my laptops as well.
He speaks fluent PSK31, in FT8...  One QSO with him earns you 5BDXCC...  His Wouff Hong has two Wouffs... Hiram Percy Maxim called HIM "The Old Man..."  He is... The Most Interesting Ham In The World!
N2MG
  • Administrator
« Reply #8 on: November 20, 2021, 04:11:35 AM »
Quote from: K5EMG
What link?
Mike N2MG
webmaster
« Reply #9 on: November 24, 2021, 05:16:22 AM »
One week now and INP fix it remedy is still working.
N5INP
« Reply #10 on: November 25, 2021, 04:57:23 AM »
Good, same here still fixed.
I would have expected more feedback on this fix by now. Maybe people like the way the scrolling was acting? I can't imagine that but who knows ...  :P
« Reply #11 on: November 25, 2021, 07:49:44 AM »
Works good, last's a long time.  :)
VE3VEE
« Reply #12 on: December 14, 2021, 04:21:19 AM »
Unfortunately, this workaround doesn't seem like a good enough solution because now when I click on the button, instead of bringing me to the first unread post, it only brings me to the top of the page.
Marvin VE3VEE
