I installed two NMO mounts with Pl259s, RG58 off of a 500 foot reel, and a Larsen Ford F150 taillight mount. One works, one does not. About 18 feet of coax between the mount and the radio. No coils, no kinks.
I disconnected the NMO antenna on the bad mount, and checked for any shorts between the center pin of the PL and the ground. None found. Infinite resistance.
I shorted the center on the PL to the outer barrel, and checked resistance between the center pin on the NMO and the ground. 0 ohms.
Yet, I moved the functioning NMO Mount 2 M / 440 antenna from the good mount to the bad one, and found 440 SWR to be great (2:1 or less across the 5 mhz 445 - 450 range) while 2 meters sits around 4:1. (I used an Antenna analyzer). The 2 meter swr on the good mount is 1.5 to 2 across the 4 mhz range. On 10 Meter FM (which is what I want to run on this mount), I have 10:1 SWR.
Aside from ripping the entire thing out, and replacing with new (which is a major league PITA), is there a way to figure out where the problem lies? I'm leaning toward NMO mount as I had to connect the cable to the mount, as opposed to having it come installed from the factory.
Any thoughts?
Thanks
