Author Topic: FT-857D Beeps when signal is received on scan  (Read 137 times)
KF7YED
« on: November 29, 2021, 06:42:46 PM »
I just figured out how to set my 857D to scan memory channels today but I can't figure out how to turn off the 2-tone beep when a signal is received during scan. I've been through the manual several times and must be missing something. Everything is working the way it should re: scanning. Scans fine and when someone keys up it stops, but beeps twice with the high-low beeps. Is there a way to turn them off? I did find out how to reduce the beep volume, so I guess I could set it to zero, but that probably applies to all beeps in all modes, no?
Thanks. 73
Rick
« Last Edit: November 29, 2021, 06:52:07 PM by KF7YED »
AC2EU
    • McVey Electronics
Re: FT-857D Beeps when signal is received on scan
« Reply #1 on: November 29, 2021, 07:00:08 PM »
Prevailing wisdom says the answer you seek is on page 94 ot the manual.
set beep volume to zero in menu item 14
KF7YED
« Reply #2 on: November 29, 2021, 07:09:00 PM »
Thanks. I guess that's the only way. I did find that setting, just hoped there was one specifically for the scan receive.
