Author Topic: Ten-Tec Pegasus EXT T/R splitter  (Read 149 times)
OD5ZZ
« on: December 06, 2021, 02:12:28 PM »
Hi
I am using the Ten-Tec Pegasus with the Ameritron AL-1500 and I have as well the Timewave DSP-599 and a QRM eliminator
While the Pegasus has one EXT T/R that is connected to the AL-1500 Relay , I am 2 short of connecting to the PTT input of the Timewave and the  QRM eliminator , anybody can help with the schematic of a box that can take care of all 3 devices that will act as a splitter for the EXT T/R on the Pegasus
Thanks in advance and Seasons Greetings
73's de Walid-OD5ZZ
N4PY
Re: Ten-Tec Pegasus EXT T/R splitter
« Reply #1 on: December 07, 2021, 06:01:08 AM »
You can simply use diodes on each line to isolate each one and make the EXT T/R line be 3 lines with 3 diodes.
Carl N4PY
