Author Topic: Icom IC-7700 WSJT keying settings?  (Read 61 times)
KB4BJM
« on: December 28, 2021, 06:55:08 AM »
Hi and thanks for your time and help. I was hoping that someone would have their wsjt settings in the IC-7700 menu changes. I receive all wsjt incoming signals. The only issue is that I forgot/lost my menu selections after I had to do a reset on the rig.Yes... I F/up. It won't key the radio. Thanks, Kb4bjm
K4LIX
Re: Icom IC-7700 WSJT keying settings?
« Reply #1 on: December 28, 2021, 11:57:37 AM »
I am using a first generation IC-7700 with a SignaLink USB on FT8/4 and other digital modes, including CW, and everything works just fine.  Set your radio to USB for FT8, not Data, you don't need that setting, and assuming you are using the DIN socket on the rear and your SLUSB is jumped correctly, yours should work.  If you want to know any specific menu setting, eMail me and I will reply with my settings.  73 de Jim K4LIX
