Author Topic: Loading driver for IC-7300  (Read 284 times)
K4NFX
« on: January 04, 2022, 07:09:09 AM »
When loading the driver for Windows 10 there is a choice for 32 bit and 64 bit. I’m not sure which I should load. Does it matter?
K1KIM
Re: Loading driver for IC-7300
« Reply #1 on: January 04, 2022, 07:33:09 AM »
Look and see what system your computer is running.
K6SDW
« Reply #2 on: January 04, 2022, 08:04:24 AM »
Google how to windows 10 version - something like that and some Windows 10 genius will tell you how its done.
GL/73
W4AOK
« Reply #3 on: January 04, 2022, 08:15:44 AM »
on your pc, type SYSINFO in the white box on the lower left of your screen (tray).
It will tell you what you have.
K4NFX
« Reply #4 on: January 04, 2022, 08:38:59 AM »
Thanks for the great answers. I have been away from fooling with computers for so long I forget these things.
WA2ONH
« Reply #5 on: January 04, 2022, 10:43:29 AM »
QUESTION: Using windows 10, do I have 32 or 64 bit Type Processor?
GoTo SETTINGS ==> Select SYSTEM  ==> Select ABOUT
Look Under "Device Specifications" ==> System Type (OS / Processor) is your answer
Displays: "00-bit operating system, x00-based processor"
Download / install this type update accordingly.
« Last Edit: January 04, 2022, 11:00:29 AM by WA2ONH »
73 de WA2ONH  <dit dit> ... Charlie
"Never be satisfied with what you know, only with what more you can find out."
   Dr David Fairchild 1869-1954 US Scientist
KC8HXO
« Reply #6 on: January 08, 2022, 04:33:57 PM »
safe bet it is 64 bit, running WIN10.
