I have an ONN laptop/tablet w/ 10" screen that is about 1 year old. I do not use it regularly as it is for Winlink ARES exercises in the field. It has performed very well in that time. I had a problem with it yesterday in which, during an exercise, I received a battery low warning as it had not been used in a few months. It stated battery at 10%, 1/2 hr remaining. Shortly after, the computer shut down. I plugged its supply in and attempted to revive it without success. After some time, pressing the on button would show a battery low symbol and it would just turn off. It has now been charging for more than 24 hours but will still not boot up nor will the screen even light with a battery indication. I checked the power supply and it is putting out the required 5 volts at the connector. Can you offer any advice? Is there a removable battery and if so, how is it removed? I tried searching the web for information but came up dry. I see various batteries for ONN but no information on how to exchange. Is there possibly an on board coin cell that has run down?
Thanks for any suggestions. 73, Jim KD1I
