Author Topic: Contemplating replacing the daily talker station to Icom SDR rigs  (Read 1078 times)
Re: Contemplating replacing the daily talker station to Icom SDR rigs
« Reply #15 on: June 24, 2022, 11:30:07 AM »
I reread the op's question, so I don't derail the thread. I don't think the 7300 is a throw away, there must be 1000's sold already, and I don't read of
many problems with the radio, I don't think I'll call my 7300 old until its 15yrs old.
I'd love to use this radio for mobile use, but I think it will last longer on a bench, no vibration, 12v dips, surges, and intermittent power downs has
to be a negative effect on this sort of radio.
WB8LBZ
« Reply #16 on: June 25, 2022, 09:18:33 AM »
For K7LZR, (this is some tough love) you need to buy the T-Shirt. You totally missed it. The functionality of the 7300 far exceeds anything you have patched together. The software available for just the 7300 only partially works with your configuration. if you step up to the 7610 there are more options.
73 (with tough love)
Larry  WB8LBZ
El Paso, TX
N2DTS
« Reply #17 on: June 25, 2022, 05:44:02 PM »
In many respects, the flex 3000 is a better radio then the 7300.
Lower built in noise level, better audio, better display and a better antenna tuna.
The 7300 can have issues, I had a power issue with my first one, HRO replaced it on the spot, the 2nd one had the screen processor fail, I have a new one I just got that is fine so far.
Easy to use and good for the money sums the 7300 up, poor audio, lots of built in noise, turn the RF gain down and turn the volume up half way, where does that racket come from?
The AGC brings up the band noise between signals a LOT, the tuner is very limits, the screen abd buttons on it are on the small side of things.
I think the 7300 would be great in a car/truck, surface mount stuff tends to be rugged and I think he radio would be fine.
The 7610 is more of the same, all the same issues but a bigger screen and 2nd RX.
With a decent desktop computer, the Flex 3000 is a great rag chew rig.
Its also easy to work on and repairable.
WA3SKN
« Reply #18 on: July 03, 2022, 08:38:24 AM »
Honestly answer the question... "Why am I upgrading?".
You will then have your answer.
Most of the radios now have memory batteries that last 7-10 years.  Some are easy to replace, some are not.  They plan on selling you a new rig every 4-5 years... that's "Marketing"!
-Mike.
