Author Topic: Swan Mk1 Linear  (Read 268 times)
Swan Mk1 Linear
« on: February 23, 2022, 08:34:12 AM »
I know this used 3-400Z tubes.  Does anyone know if 3-500Z tubes can be used, or are they physically too tall to fit the box?
KB7TT
Re: Swan Mk1 Linear
« Reply #1 on: February 23, 2022, 11:03:14 AM »
I have a MkII and use 3-500s with the low profile plate caps, works great.... I think the cabinets are identical.
fyi
Re: Swan Mk1 Linear
« Reply #2 on: February 23, 2022, 01:12:55 PM »
KB7TT
Mni tnx. I'll see if there are any other replies...
Maybe bigger problem is no tuned input, which some SS rigs might object to....
vy 73
Peter G3RZP
W5RKL
Re: Swan Mk1 Linear
« Reply #3 on: February 28, 2022, 02:06:56 PM »
You should read up on the differences between the 3-400 and 3-500 tubes. The tubes are different.
Click the link below for further details.
https://www.rfparts.com/3-400-3-500comparison
Mike W5RKL
www.w5rkl.com
Re: Swan Mk1 Linear
« Reply #4 on: March 01, 2022, 01:17:44 AM »
The big difference is the height. The 3-500Z has slightly lower amplification factor (160 as against 200):  with the same filament as the 4-250, 4-400 and 3-400, the peak cathode currents will be the same.  At a pinch, a 4-400 can be substituted if the extra height isn't a problem- which in the case  of the Swan it almost certainly is.
