Author Topic: Lutron wireless switches  (Read 239 times)
N4NLN
« on: March 01, 2022, 05:13:07 PM »
Anyone have any experience with Lutron wireless lighting controls? NOTE: these are the control switchplates - the dimmer/ssr packs are separate and a control processor talks to the control surfaces and then tells the dimmer packs what to do.
i’ve been told the wireless switchplates are on 430MHz
in a dedicated allocation. Even assuming that is true, a 440 rig
could potentially argue with desensing if nothing else.
If you know what a Litetouch forklift upgrade is, you understand my problem in the large. What I don’t want to do is wear out the forklift and then find i have an EMI problem.
Any experience info much appreciated.
      -mo
     n4nln@mac.com
K6AER
Re: Lutron wireless switches
« Reply #1 on: March 01, 2022, 05:46:45 PM »
The ham band for UHF is 420-450 MHz. I doubt their frequency in in the ham band. Besides what is the chance you are going to be using the switch while operating on UHF?
« Reply #2 on: March 01, 2022, 06:38:28 PM »
Many things operate in the Amateur 70 cm band. These lighting controllers are only one example.
  Communicates using Radio Frequency (RF) at 431 MHz to 437 MHz. •  Thousands of system addresses prevent interference between systems. •  Can be assigned to control blinds, curtains or lighting devices that are within a 30 ft (9 m) range. •  Can be configured as a scene or zone control in GRAFIK EyeR  QS wireless applications.
« Reply #3 on: March 01, 2022, 08:01:57 PM »
Strange but my garage door opener remote says that it operates in the same frequency range.
« Reply #4 on: March 01, 2022, 09:10:53 PM »
Lots of stuff can be bought and used license free.
https://www.amazon.com/433mhz-transmitter/s?k=433mhz+transmitter
K6AER
« Reply #5 on: March 01, 2022, 09:47:49 PM »
I stand corrected.
WA2ISE
« Reply #6 on: March 02, 2022, 12:57:03 PM »
I think we share 420-450 MHz band with the military.  And that they like us as neighbors, and wouldn't want others in this band. As hams and the military share the band well.
