Author Topic: Larsen Mag Mount and A Diamond Antenna SG7500NMO  (Read 203 times)
N6HPO
« on: March 06, 2022, 06:36:01 PM »
Hi Everyone,
Will this combination work [stay on the top of the pickup cab at California freeway speeds(!)] My 2003 Tacoma P/U is a loaned vehicle, temporarily. I'd like to use the antenna on the cab's top and not worry about the mag/antenna flying off at 65 MPH...
Many thanks for taking the time to respond.
N4MJG
Re: Larsen Mag Mount and A Diamond Antenna SG7500NMO
« Reply #1 on: March 07, 2022, 07:34:27 AM »
i never any have mag on top of my doing 65 mph you may try drill holeas of allen applegate if remember his name k0bg on his website !
JACKIE GREEN
KG7VQ
« Reply #2 on: March 07, 2022, 08:33:26 AM »
I have used Larson mag mounts in the past and never had problems, even driving across the country at freeway speeds. I now use them for event APRS trakers.
N9DRY
« Reply #3 on: March 07, 2022, 08:34:40 AM »
Hi,
I am using a Comet SBB-224 (tri band with size and profile similar to the SG-7500) with a Larsen mag mount.  This has been working quite well.  It has been blown off the roof but only 2 or 3 times in 2 years and a couple of tip overs.  "Freeway speed" with a brisk headwind or wind from either front quarter will do it.  I have had many more tip overs and a few 'off the roof' incidents due to overhead obstructions.
This size antenna seems to be the largest that this mag mount can handle.
KM3F
« Reply #4 on: March 23, 2022, 11:51:07 PM »
You don't specify the size of the antenna or the diameter of the magnetic mount.
A 5 inch magnet and a dual band 2/440 antenna about 36 " will hang on well beyond 90 mph.
My Larson mount is on an Alum cab Ford F150 between the rear light and cab.
The mag hangs on so well I have to slide it off the mount to get it free.
Only other way is to invest in a three mag base mount.
Your antenna is also 36"+/-.
