Thank you to everyone who interacted with me, the antenna length is 2.5 meters,
the tuner is in the back of the car,
the wire feeding the antenna is 1.2 meters long,
the antenna is installed on the base of the spare tire,
I made a 70 cm iron base and installed the antenna on it,
the height of the antenna below the ground is 1.7 meters, and the height of the antenna above the ground is 4.2 meters.
Honestly, I make qso to the United States, Spain, and Indonesia at a range of 20 meters and 15 meters, and the results are amazing. As for at a scale of 40 meters, I spoke to Japan, but I separated the whip antenna and used Long wire 12 meters long .
