Author Topic: Any thoughts on the future of vacuum tube supplies?  (Read 776 times)
VE3WGO
Re: Any thoughts on the future of vacuum tube supplies?
« Reply #15 on: March 28, 2022, 08:30:19 AM »
With the ongoing and high interest in vacuum tubes for musicians, audiophiles, vintage audio and radio equipment, etc, the prices might rise to the point where it become feasible to restart manufacturing them in any country including the USA.
There is no doubt at all that my PP 6V6 monoblocks sound different than my Marantz super linear amp.  Different, not worse.   Distortion on my Yamaha solid state amp just isn't the same as the 6L6 Traynor.    Different, not better.  It's a matter of taste.  And then there is repairability... did you ever try to find power transistors or power IC's for repair?  Good luck on that...  it's usually much harder (and sometimes more expensive) than finding tubes... even now.
I sigh when I hear or read people biased against something as old technology therefore it must be inferior.  Being newer does not necessarily mean better, nowadays it often just means cheaper.
The Triode was prototyped in 1906, the germanium point contact transistor was prototyped 21 years later in Bell labs.  Transistors started out being more expensive than tubes in the 1950's but eventually got cheaper by the 1960's.  A lot of new technology breakthroughs were going on in those decades but it might be concluded that making tubes is easier than making transistors, so it's just a matter of time before the economics of tube-making makes a good business case in more countries, and more tube factories spring up.   I sure hope so....
73, Ed
PS: speaking of business cases, the Shuguang tube factory eventually closed because a real-estate developer wanted to buy the land.  There is a lot of money to be made when something is scarce (in this case, land) but the demand is strong.
W2EAF
« Reply #16 on: March 28, 2022, 09:04:17 AM »
We all rely ultimately on the commercial world for fresh stock but, from an individual's viewpoint, my best experience has come from alliances with other like-minded people.
I guess maybe I should have posted in the boat anchor forum! ;D. But I agree with VK6HP, and thank him and all for the thoughtful responses.
Rob
W8HDU
« Reply #17 on: April 07, 2022, 01:39:33 PM »
With the current inasnity of the Ukraine/Russia war (and I am by no means being political or trivializing the suffering of millions of people by bringing this up) I have noticed people seem to be hoarding tubes the way they did with toilet paper a couple of years ago. 6L6, 6V6,7025 12AX7 etc are out of stock everywhere now it seems, and the few you come across are incredibly expensive.
Those of us that do classic audio are wondering the same thing.  There is supposedly a U.S. company (maybe "JJ") who was going to invest in the market.
The Russian tubes have sort of gone bad.  You can get 811s from them, but you play the devil trying to get a pair which has the same characteristics.  And the Chinese tubes on Aliexpress are hit or miss.
Fred
"Quisquam dignitas effectus est dignitas super effectus!"
WA2ISE
« Reply #18 on: April 08, 2022, 11:34:12 AM »
If you're homebrewing vacuum tube audio amps, you can use some "TV tubes" in the circuits.  Signal level tiodes will work fine, and "sharp cutoff" pentodes work fine as well.  Outputs can be tubes intended for vertical or horizontal deflection outputs.  And in homebrew radio receiver circuits, old TV IF amp tubes will work fine.  Damper diodes will work as rectifiers.
