Pages: 1 [2] 3   Go Down
Author Topic: What are you preparing for?  (Read 1351 times)
K2WPM
Re: What are you preparing for?
« Reply #15 on: April 13, 2022, 06:45:15 PM »
I hate to give a serious answer, but...
I am surprised our electric grid has not been attacked (that we know of), so I think we should be preparing for an episode where large region(s) without power for extended periods.  There have been hearings on this going back to the 1980s, but I don't know of any serious effort to address the weaknesses.  Not debating this, just putting it out there as a real and probable disaster scenario.
This suggests we radio-preppers should have batteries to allow operation for at least a few hours a day ... two 15 amp hour Bioenno batteries.  Also a way to charge them, first a generator and longer-term, 100 watt solar panel(s) and charge controller.
Also need to consider you will need both local - VHF as well as longer - HF communications.
I have HTs for VHF and an HF radio.
And yes, guns, ammo, food and water.
Quote from: W5UAA link=topic=136018.msg1260562#msg1260562 date=1649765932
[img
https://3.bp.blogspot.com/-3lAX7Hi8J5A/WIE9aFgQApI/AAAAAAAAIho/79z3PSv4vMsPmSakkC9Avf6BpAFAujPUgCLcB/s1600/Amish_Family_Buggy.jpg[/img]
AK4YH
    • Radio Prepper
« Reply #16 on: April 14, 2022, 10:17:19 AM »
Preparing for one thing in particular is called gambling... And the house always wins. Prepping is not something for which you can pick and choose what you invest in. It is hard cold survival and implies learning and investing in things that interests us as well as those that do not. There are no aspects of prepping that you can favour or ignore. So preparing for one thing makes no sense. Either you prepare for everything, or you don't prepare. Now we all have preferences, and that's fine, but even if we favour certain parts, we can't ignore any.
Gil.
WW5F
« Reply #17 on: April 17, 2022, 11:32:25 AM »
Prepping.  When you think about it, you have to get down to the basics.  What is "prepping for everything?"
Maslow's hierarchy of needs:
Self-actualization
Esteem
Love/belonging
Safety
Physiological
All you can really prep for is the bottom two.  That translates into:
Food
Water
Fire
Shelter
...and protection against those who want to take the above away from you.
And in our case, only after that's met, then radio.
KB8VUL
« Reply #18 on: April 30, 2022, 11:03:56 AM »
Right,,, but what I am asking is for things like you know there is a building that is typically used for a shelter.  You have installed a wireless mesh to it connected to a satellite Internet connection for people to use in the shelter.  You have build charging kiosks for people to charge their phones during  a disaster, and maybe it's battery powered so it doesn't need utility to work.   That sort of thing.
US7IGN
    • https://www.us7ign.com/
« Reply #19 on: May 01, 2022, 02:15:53 AM »
Maybe someone will be interested to know how everything looks during the war.
Radio.
Most likely you will be banned from transmitting. But you yourself will decide how to act according to the circumstances. If your safety will depend on being able to call for help, then it would be foolish not to use the radio for this. You must understand that in the occupied areas or in the area of ​​​​combat operations your signal will be immediately detected and a mine can simply be sent to you. The most important benefit of radio is the ability to listen. Amateur radio chatter is the last thing you'll be interested in.
I was extremely interested in listening to two things - the conversations of russian pilots (yes, they use the AM band without encryption) and the local police and amateur repeaters that were used by the territorial defense.
Air raid alerts sometimes went off after the first explosions, and if you started to hear the pilots, that meant you had 10-15 minutes before they were overhead.
I think it is not necessary to explain the importance of knowing the situation in your area or on the next street.
You must understand that electricity can run out at any moment, and with it the Internet and local FM/AM radio stations. Therefore, you need a good little receiver to listen to the news on medium and short waves. This will help you make the right decision when you need to urgently leave your place.
So my base Icom IC-756pro3 transceiver was packed and goes under the bed the first day and I was listening to the little all-wave Icom IC-706mk2g. It was also ready to go with me in case of evacuation by car. For evacuation on foot, a home-made little QRP transceiver with built-in tuner and battery was prepared. The coil of wire and power are always important.
Food and water.
I always had a supply for 2 weeks and I was practically not affected by the fact that the stores immediately closed and nothing could be bought. I immediately decided for myself that if the situation does not improve in 2 weeks, then there is no point in staying there.
Shelter.
If you understand that you need shelter, then you need to leave. It will not help at all from rockets and bombs, and even more so from enemy soldiers who can easily get you out of there.
WW5F
« Reply #20 on: May 02, 2022, 01:46:13 AM »
Some of you may not know this, but WLAD (US7IGN) is a solid voice of *real* advice when it comes to ham radio, emergency communications and "prepping."
He's not allowed to leave Ukraine and his family is now surviving in Krakow.
Most people are surprised to find out what they "think" is necessary is not what they "really" need when you start to feel the waves in the ground (like large ripples in a pond) from the large explosions happening within a mile of you.  (I experienced this in Baghdad in 2003/2004.)
And Wlad is in a situation where "transmitting" can allow someone who's trying to kill you to actually paint a target on you from a long distance.  (I did not participate in any ham radio in Iraq.)
From what I've seen/heard, we hams, here on this side of the pond, are woefully unprepared if our lives are turned upside down from any natural or man made disaster.  In reality, as Wlad points out, ham radio's only real value to us during times of disaster is listening to what others are doing for our own situational awareness.
Thanks Wlad.  Stay safe.  (I need to change my call sign on this sight... WW5F)
US7IGN
« Reply #21 on: May 02, 2022, 03:06:01 AM »
Thank you Guy!
Probably worth adding that the psychological state is also very important. I spent the first few days with a friend who was very nervous. People tend to do stupid things in normal situations, but in a stressful situation, they just lose their heads. Therefore, the first thing I did I was forced him to listen to the radio and look for useful information on certain frequencies. He calmed down almost immediately. It distracted and captivated him. I stopped smelling the fear that had upset me.
Also, you will always have the confidence that you will be in touch with your closest friends or pass on the necessary information to your loved ones if you loss the communication. You just need to agree in advance how you will do it. For example, I told my wife that if I did not get in touch on the Internet or by phone within 24 hours, she should check my activity on the site http://www.reversebeacon.net/. If the problem is only in the loss of communication, then I can always send my call sign a couple of times and this will mean that I am at least alive.
WW5F
« Reply #22 on: May 02, 2022, 05:14:00 AM »
Thank you Guy!
Yes, it's been proven time and time again in dire situations, some people will literally freeze up, many will listen to anyone who sounds like they have authority, and a few will be level-headed enough to direct the people around them to safety.
And using reversebeacon.net as a means of sending a one-way "I'm OK" message is BRILLIANT!  I'm going to remember that one!
KB8VUL
« Reply #23 on: May 08, 2022, 05:32:46 PM »
And while ham radio COULD be a method, GMRS in the US is also a viable means for the first 48 hours as well.  And the nice thing with it is you get the license and everyone in the family is covered to use the radios. So you either put up a repeater with 48 hours of battery backup, or you find one someone else has and you help him out with the battery part so there is something there.   Now NOTHING is 100% reliable,  But that being said, my setup is on an AT&T tower that is rated for 10 PSI with the horns on it.  And while that's not a nuclear blast, it's gonna take an F1 tornado and an F3 off the side.  you start talking F4 and nothing sticking out of the ground stays up for the most part. Tie the top of the antenna into the structure and it's pretty stable.  Put one of the zero gain UHF ground planes on it that were used for Air Force One communications that were rated for a 600 MPH wind with the proper mount and it will not talk far, but it will be there through most disasters.
KD0VE
« Reply #24 on: May 15, 2022, 06:18:57 AM »
Years ago I had a couple field service guys that worked for me from upstate NY.  An ice storm that took down the utility poles caused their rural homes to be without power for several weeks!
I assume an upset that would disable power and transport for several days or weeks.
This means I need a reliable source of water, stored food, fuel for heating and cooking, a modest off grid power supply, and some communications capability.  Also a way to secure my resources if the upset is more than a few days.
All of those things can be acquired without a significant investment if the limit of the upset is weeks.  Water and stored food can just be a somewhat larger than average pantry.  Lots of options for heating and cooking fuel.  A typical HF/VHF ham station with a couple deep cycle batteries would have everything needed with the possible exception of a NVIS antenna which would be easily implemented.
If the scenario is an upset that lasts for months a much greater effort is required.
WB8VLC
« Reply #25 on: June 07, 2022, 10:31:09 AM »
Running out of a steady supply of dark STOUT BEER and fun women,  everything else beyond these two items is of minor importance.
Or could that be stout women and fun beer?
Nothing else matters beyond these two items and I'm happy to report that there is no shortage of any of these two critical items here in the Pacifist Northwest.
So I'm still a happy camper for sure and nothing else matters when these two items are still available.
When one or both of these critical items is in short supply then WE WILL BE ROYALLY DOOMED!
« Reply #26 on: June 09, 2022, 09:17:22 AM »
There is much wisdom here.  What, and how, you "prep" has to do with what you are going to prepare for, and how long it lasts.
"Preparing for everything, for months" is great if you can do it.  But what's realistic?  What's likely to actually happen?  Can you afford to buy the right property and invest in a significant infrastructure on it?
If there is an EMP event, I submit it is likely that even the most sturdy "prepper" is going to be hurting.  All kinds of critical infrastructure is likely to be wiped out.  The odds of not having something you need (water, medicine) is fairly great.  Kudos if you can out-think everything.  But nobody in the US has been put to that test.  Ever.
Anything else is likely to be regional; even war, to an extent.  As long as you can drive -- or even walk -- to somewhere else, you can get by until things improve.
In my case, we had two events in my lifetime.  One was a devastating flood.  But, it was hit and miss.  I lived on the high ground and was largely unaffected.  I even had power.  Thousands were not.  But, they went to Red Cross shelters and within a week, things were normal enough that everyone could go home.  Including folks like me that volunteered a bit.
In the other case, we had a freak accident that crippled the local AC power for about three days.  The whole town was affected, about 100,000 people.
Well, we all ate up our refrigerated stuff pretty fast.  But, as long as you could drive, or even walk, to the next county, your life was more or less normal.  You could get food, water, whatever you needed.
For my two actual events, then, all I needed for "prep" was a bank account with a little cash in it.  And, barely that.  I didn't even have to leave home.  Maybe a working bicycle is the best prep for anything short of EMP?
Some of this is a health statement.  If I were diabetic or needed dialysis, a lot of these scenarios, the ones involving very long term outages means I have to refugee somewhere fast or else simply die.  If you are a regular person, then a six month shelter is fine; you can stand having your generator break down for a day or two.  But, if you have problems like diabetes or dialysis, your margin for error is much less.  Being a refugee makes a lot more sense if it is available to you.
To me, "prepping" is about a situation so dire that being a refugee is impossible.  Being a refugee really sucks -- you have to depend on the kindness (however well or ill organized) of strangers.  But, it seems to work surprisingly well.
The only scenario I can identify that probably doesn't allow one to be a refugee is the EMP event and I'm dubious if anyone can prepare well enough for that one.  All you need to do is neglect one thing -- or have it spoil or something -- and you're no better off than anyone else. But, it's a free country -- try if it is important to you.
KK4GMU
« Reply #27 on: August 06, 2022, 12:36:53 PM »
Gil.
What makes the most sense for me is prepping for the most likely scenarios in your region of the country.  I don't concur with the "all or nothing" approach.  I do what I can for the most likely events.
Being in Florida, the most likely disaster is hurricanes.  Besides that, I suspect an EMP or cyber attack on the grid is the next most likely possibility.  No, most of my "stuff" is not hardened, although I do have HTs in ammo cans. With power out for a week, I suspect the fuel to generate power to sewage lift stations and water plants would run out unless the county is better prepared than I suspect.  Those of you who have well and septic have fewer worries.  You just need backup power that will last the duration.
For the ultimate SHTF situation nationwide...a farm, cattle, a crew, and good defense.  But the odds for that happening compared to a Cat 4 hurricane are much slimmer.  And the part of Florida I'm in even a Cat 4 hasn't occurred in several decades.
IC-7100, RSPdx, AT-D878UVII-Plus HT, TGIF Spot
« Reply #28 on: August 06, 2022, 01:42:44 PM »
Prepper motto, save the last bullet for yourself.
WB6TIX
« Reply #29 on: August 10, 2022, 04:10:26 PM »
Something more mundane....summer storms in our rural area (where 20 acre lots are tiny).
When the summer storms hit, flash flooding closes roads for 4 or 5 hours.  Often the electricity also goes out for 4 to 48 hours.  The phone company has decided that their gear along the street does not need battery backup, so the phone service is out as long as the power is out.
So...electric-phone-road problems at the same time.
Pages: 1 [2] 3   Go Up
