No.
However... have you tried to measure it?
I would expect about 5 millivolts across a 2000 ohm impedance.
Concerning the Wouxon KG-UVD1...
It is part 90 certified, not part 97. Expect 2.5 kHz deviation default.
It appears deviation can be adjusted, but is labelled "bandwidth" in the manual.
Remember that the "control operator" is responsible for the output of the transmitter.
-Mike.
